Interior Elevation Tag
    Okay, this is driving me insane. I want to use the round interior elevations tag, but I don't want it to display the view name. I can't figure out how to change it.
    I've found the elevation mark pointer family in the project browser. And, there is a family type for detail number and view name. However, when I try to edit the elevation tag in my view, that family is not there. It just says 1/2" circle. I can't find that anywhere.
    Dan
    1. Is the elevation placed on a sheet yet? If not, place it on a sheet and see if the detail number fills in.
    2. You can specify "Title on sheet" under the View Properties, and make it different than the name of the View itself.
    3. In the pointer family, check and see if there are 2 labels: Detail Number and Reference.
    Other than checking these things, I can't see anything else obviously wrong here.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      I've had a similar issue in a project I did a few months ago, I think I just ended up keeping the name because I couldn't figure out how to change it
      mind you this was prior to the Revit Forum days
      Juan Carlos Moreno
      Sisley Cosmetics
        Go to the Manage tab and then choose "Additional Settings", then "Elevation Tags". Here you can edit the 1/2" Circle and 1/2" Square families. The only parameter available to change is which pointer family the elevation tag uses. By default it is set to "Elevation Mark Body_Circle: Filled Arrow and View Name". You can change this in the pull-down to "Elevation Mark Body_Circle: Filled Arrow". Then you should be golden. Hope this helps...
          I wasn't sure what version of Revit you are using so I did this for 2010 and 2011 as they are both different. The video has audio on it so you will want speakers.
          http://screencast.com/t/FqOgteKFPgh8
          Edit: although if I had read more carefully I would have noticed it was 2011.
          Edit Edit: Also, the label that is simply Ref should not be deleted, that is for Sim/Typ/Rev callouts.
          hypnox1
          Senior Member
            Yes! That did it. Thanks a ton.
            Yep, I'm on 2011. Unfortunately, net police prohibit me from viewing anything they deem entertaining. I tried to tell them it was a Revit video, but they hear me hootin' and hollerin' when I figure something out on Revit so they assume it's entertainment. lol
            Dan
              Great
              No problem. Glad I could help.
