Phases
    Phases
    I am creating a new phase for my rebar detailing, but right now every time a create a new view the phase defaults to "Show All". Is there a way to get this to default to "None"?
    Maybe you should create a view template from the first one, then apply it to other views.
    And also in the manage window for filters, you just have to check the option "apply to similar view ....".
    good luck
    Julien
    P. DAC
      It is a phase filter though, not a filter. Although a view template would work for this...was just hoping I could get it to change how it defalted instead of changing it after.
        I duplicate view when playing with phases filtered views.
        Julien
        P. DAC
          Yeah, as above right click duplicate view.
          Mark Balsom
            This works well with plans...but I am not seeing using this on elevations and sections. I want to cut a section where I need it, not duplicate, go find it, then move it to where I want it.
              Sorry didn't read into your first post completely, try this.
              While in a section view,go to view templates select the type of section you want to change defaults of (or what ever view type you want) , select phase filter type, THEN check the small check box bottom left corner.
              Then you should be good to go, and every section after that will be to your default.
              Mark Balsom
                While in a section view,go to view templates select the type of section you want to change defaults of.
                Just a note, if you are in any sort of plan view you can't try to set the defaults of the view template of sections or elevations etc. if you try you will see the "Apply automatically to new views of same type" will be greyed out.
                and visa-versa. see image
                Mark Balsom
                  when cutting a section it will absorb the phase and phase filter of the view you're in, so as long as you have your plan set to None for your Phase Filter the section will default to that.
                    It takes on the Phase, but not the phase filter...
