make a selected wall invsible
    I know I can make them ALL invisble in VG
    can I select a single wall and, without changing the wall type, make that VG for that wall transparent without affecting all the other walls?
    Thanks
    james
    Thanks
    james
    select the wall, right click, and select Hide in View/Element
    Dave Jones
    "I am NOT a Revit tutor!"
    Last edited by Dave Jones; February 22, 2011, 03:28 PM. Reason: added the Element part
      ah - i did not explain too well - i want it transparent - not hidden. I can do all walls in VG by ticking transprent - just wondered if I could do it to a singe wall.
        Select the wall. In the Modify tab, select the paint brush icon under the view section. Select "override by element". When the box comes up, check transparent.
        Dan
          Add a shared parameter to the wall called transparent it can a yes/ no parameter, then based on this parameter, you can add a filter.
          In the dialog for the filter you chose the parameter created to filter all walls that have the transparent parameter assigned to them and change the graphic representation of that element based on the filter.
          Juan Carlos Moreno
          Sisley Cosmetics
            My way is way easier. lol
            Dan
              Wow, this is a lot faster! I never even new this feature existed till today. Thanks for teaching me something new REP for you!
              Juan Carlos Moreno
              Sisley Cosmetics
                You can right-click and "Override Graphics in View... by Element" as well.
                Not really any different than Dan's method - just if you prefer Right-click to Ribbon-pick.
                Both get you to the same place.
                Dave Plumb
                BWBR Architects; St Paul, MN
                  even faster! I love this place :thumbsup:
                    Yep, I keep forgetting about the right click menus. I was a keyboard guy in ACA. I just haven't set up all my keystrokes in Revit yet. I'm just getting to where I know what commands I use often. lol
                    Dan
