Lost transparency, png-images
    Why did trees, inserted as images in elevations, suddenly loos their transparency? If I insert the same image again (png), the is transparent as expected.
    I know that the trees in my garden will loos their transparency in a month or two, but that's not Revit :-)
    Søren
    Just a first thought would be - is the .png image set to foreground or in the options bar?
    You probably know this, but just in case, if not in the foreground the image and transparency will not display in front of model objects in a View.
    William
    William Sutherland rias riba
    WS Architecture Ltd
      The .png is set to foreground.
      Søren
