column display and architectural wall
    I am frustrated, trying to get the box showing for this column that's placed inside the architectural wall. If anyone got this figured out, please let me know how to set it up.
    thank you.
    use structural column instead architectural column
      What's the general rule on using architectural columns? It seems they are great for pilasters and decorative columns but not much else. Am I correct on that?
      chad
        yep. I never used them. They also give you some wrong material quantitis.
          Hi gaby 424 thank you for the tips. I have used the structural column now but it doesn't show me the X crossing on it viewed under floor plans. how do i set that up?
          thank you
            what does it mean under floor plans? have you draw the X as symbolic lines in the family editor? Also the X lines should be visible at your desired level of detail if you set it in the Visibility Setings panel (button available in family editor if you select the X lines)
              i havent drawn the x lines on the family editor yet. that i havent figured out =_= how
                use model or detail lines in your floor plan view in the family
                chad
