Has anyone made a DCVR/RFI Title Block
    Has anyone set up a DCVR title block (8.5x11 and 11x17) for sending a revision to the contractor? I was successful in setting up two of our company standard title blocks, and now I am currently working on one for DCVR use. Should I be using the fields, 'Current Revision------' from within the Edit Label dialogue box? Is there any underlying issues with this approach?
    Thanks,
    Chuck
    Bettisworth North
    I apologize; I don't know what "DCVR" stands for.
    Leanne Zaras, CDT, LEED AP
      Could it be "Design Clarification Verification Request" ?? The abbreviation can be read as DCVR or DC/VR.
      I use the Current Revision Description parameter with the Current Revision Date and it works fine, see attachment.
      Alexandre Cantin
