Is their a way to attache a wall to a stair? I have a tunnel that steps up and I am wanting to attach the wall to the stair. I am looking for something other than editing profile.
Attaching Walls to Stair
In place wall, void sweep. Or model your stair as a roof....;-)Julien
P. DAC
Originally posted by gdoherty0102 View PostThat works for when the wall is on the underside of the stair, but if it is on the top you get some odd looks at the ends of the stairs.
Wall attach base (or and Top) to ref planes. Then cheat with split face and paint material (stair material)Mark Balsom
Originally posted by DrAcI hope they dont listen to you then, because 'edit profile' is an essential tool in our tool-box. Why would you tell them such a crazy thing anyway?
Hi All, I need to model this stair, I know that it seems not difficult but I don't figure me out how I can model the part that's marked in red, any suggestions...October 25, 2014, 05:18 PM
Guys,
For our construction process we use precast stairs. In this particular case we are not only creating the precast 'main stair flight',...April 17, 2013, 11:57 PM -
Hai,
How can we create stair using with stair calculator?January 9, 2012, 08:09 AM -
Well I'm struggling with Revit 2018.3, there are a lot of things going bad since I've started to use it, today Stairs by sketch don't want to work at...July 4, 2018, 12:44 PM
as per attachment, when i sketch the stair its look like a broken stair, why?
October 26, 2014, 12:18 PM -
Monumetric Footer In-screen
