When Column is attached to Roof
    When I attach a column to a sloped roof, the intersection is not good ( not like attach a wall). How must I do ?
    You'll likely need to tweak the column family and introduce an angle parameter (use Reference Lines) to control how the column meets the roof.
    Greg McDowell Jr
    about.me/GMcDowellJr
      When attaching column, try playing with these different settings in the "options bar" for how the column cuts (attaches), plenty of options and worth having a play.
      Mark Balsom
        mark b is correct. Also there are column attachment styles in the properties of the column. But I think these only apply when attaching to other structural members such as beams...
          Mdravdvies is correct...
            Hi guys, I dont have this option in revit, yo have any idea why?
              Because you're not using a structural column and that feature doesn't work for architectural columns ?
              Kamran Mirza
