Generic Annotation Always Vertical
This topic is closed.
    Help before I waste more time. Is there anyway to get a generic annotation label to be always vertical.
    Mark Balsom
    check off "rotate with element"?
      Yep tried that, dosn't work
      Mark Balsom
        I figured so much... but it never hurts to state the obvious. I wouldn't know then. This is exactly what this check mark is there for to my knowledge.
          I thought "rotate with component" was for Tag families, I am not really sure it does anything for straight "Generic Annotation" Families
          I am not sure if there is a built in way to solve this problem, but one way may be to nest in the text element as a separate Generic Annotation family, then all you need to do is place one for each orientation of the family, you can then control which label shows with a visibility family
          It would require manual adjustment for each placement, or you could just make two types if that is easier..
          Revit BLOGGAGE
          http://www.revic.org.au
            I don't get these kind of quirks. Why put the check in, if it doesn't do anything??? So make it work, or delete it all together...
              Thanks Ben
              Tried this approach but seems clunky. "Always vertical" seems like a simple request for annotation ??
              Mark Balsom
