Topography Surface / Section Box ?
This topic is closed.
    Anyone knows how to get rid of the aprox. ½" setback, that apears on topo´s when cutting it with a section box ? This has been bugging me for a long time, and I´ve not been able to find a solution... maybe there just aren´t one ? :beer:
    What do you mean, the 1/2" set back? You arent talking about the goofy thickness of the site, thats controlled completely randomly in the Site settings, are you?
      when you cut with section box your geometry and you go to an axonometry and zoom in to a geaometry(fundation) you will see that the cut plan of topo surface is not coplanar with the cut plane of geometry. Looks like sectioned geometry is detached from the hatch of toposurface(in axonometry).
        Spot on Gaby, that´s exactly what I mean
        Also see attachment for further reference :beer:
          Almost seems like that is be design to give the structure some 'pop' in 3D...kind of makes it stand out against the topo even though that is completely unrealistic
          Chad Koscinski | Architect
            I was thinking along these lines: If they were flush, then there might be the typical display issues where two elements fight for the same pixels and you get those horrible artifacts in the view. Since you really cant "cut geometry" from the Topography, the this is Revit's way of handling the issue
            Juan Carlos Moreno
            Sisley Cosmetics
