Stair Calculator
    Stair Calculator
    Hai,
    How can we create stair using with stair calculator?
    please anybody help me..
      By enabling the Stair Calculator in the Stair Type properties dialog?
      Otherwise, you´ll have to elaborate a "little" on the issue you are having.
        hi,
        I wish to know that what is the use of stair calculator in stair type properties box?how we can make it usable during the creation of stair?can u give an example for stair creation using stair calculator.
          The calculator will define things like max riser height, min thread depth, etc. And use those rules when laying out the stair sketch.... Nothing fancy really.
            Ok. But the riser height, tread depth ,total height.....all these parameters we can enter in the type properties box and can create the stair according to those values. Then what is the need of stair calculator?
              The Stair Calculator is merely an assistant to provide the appropriate entries (riser height/tread depth) for the type according to the typical stair design rules you'd find in the US as well as other (European) countries (e.g. Germany, et.al.)... if you provide those entries directly in the stair type dialog, you won't need to use it...
