Material Above Column
    I have a building with columns on the corners. The columns do not go all the way up to the roof line.
    Technically, the wall is CMU with manufactured stone veneer, and so are the columns. I could miter the wall at the corner and add the column, but then it shows the stone between the column and wall in plan, which isn't correct.
    If I create a CMU wall where the corners are, it's correct in plan; but how do I model the material above the column. That needs to go back to stone. I really don't want to float a few small stone walls in there. Is there another option?
    Dan
    Edit Profile on the perpendicular walls?
    Greg McDowell Jr
    about.me/GMcDowellJr
      Usually unique shape materials i model with model with in place, few minutes and its ready. Why not?
        Nope. The walls overlap and won't miter.
        I have several of these. I try not to use in place models if I can help it, but that may be the solution.
        Dan
          I wound up just adding a small wall above to fill in the gap. I guess that's the best solution.
          Dan
            I would agree....
              Originally posted by mdradvies View Post
              I would agree....
              Well in that case, it IS the best solution. :laugh:
              Dan
                Just cuz he agreed... WTF man. If Mark Twain told you to jump off a bridge cuz he thought it was the best solution.... wait where was i going with this? Awe hell its too early.
                -Alex Cunningham
                  and...so it begins
                  Happy New Year Alex!
                    Originally posted by Dave Jones View Post
                    and...so it begins
                    You know you missed me. It was so quiet around here last week.
                    -Alex Cunningham
