Mullions
    Mullions
    I've been struggling to make custom mullions for curtain walls (they don't seem to load into my mullion icon, but into the project)
    Have you got a good tip or idea? please share
    life's good :wine:
    simone allers
    senior draftsman
    Envisage Design Group
    I think you forgot step 2:
    Mullions are essentially profiles, just like a wall sweep, gutter, etc. You have two take two steps to actually use them:
    1. Create and load into project.
    2. Select the element on which you want to apply them (in this case a CW). Go to type properties and assign the profile there to the family.
      I'll have a try again
      life's good :wine:
      simone allers
      senior draftsman
        The thing is, I'm creating a Profile Mullion then Loading it into the Project. I want to select Mullion in the Modelling Design Bar, but it then says I have to load a Mullion. How do I make this Mullion?
        To be used on curtain walls.
        life's good :wine:
        simone allers
        senior draftsman
          I think you have to select an existing mullion and then duplicate that and change the profile to the one you loaded.
          Make sure that the mullion is not pinned, or else you won't be able to duplicate it to create your new mullion
          Hope this helps.
          JCM
          Spanish Moderator
          Juan Carlos Moreno
          Sisley Cosmetics
            I don't have one
            life's good :wine:
            simone allers
            senior draftsman
              I don't have one
              I load the Imperial curtain wall profile that's in the Revit Library, but then it does this:
              life's good :wine:
              simone allers
              senior draftsman
                Oh i see,
                You probably purged the family at some point.
                Just open a new project> draw a curtain wall with mullions, copy and paste it into your project and it should fix this
                HTH
                Juan Carlos Moreno
                Sisley Cosmetics
                  Ah Ha!! Yeaah!!
                  You are clever :thumbsup:
                  I'm at a new company who has set up their own template...
                  life's good :wine:
                  simone allers
                  senior draftsman
                    Could you post an example project? I find it difficult to recreate this...
