does anybody know if it´s possible to create custom patterns using AutoCad? Or any other graphical tool to create *.pat files
how to create custom patterns? *.pat file...
Funny, I've only just started playing with that myself for the first time today as well! :laugh:
The question that's not answered (by using hatch 22) is how to work the patterns that you create into the Revit.pat file and have that available to all from the get go (at or after install)
I imagine (?) it's a simple case of copy/paste, no?
Originally posted by snowyweston View PostFunny, I've only just started playing with that myself for the first time today as well! :laugh:
or
You can edit the default .pat file location. Open your .pat file in "notepad" and copy/paste into Revit default .pat file. Make sure you turn off "read only" first or you won't be able to save changes.Last edited by mark b; December 13, 2011, 10:04 PM.Mark Balsom
I have used Hatch 22 before and it works pretty well for "stacked" pattern,then I have attempted to make a running bond pattern a few times, and they all came back stacking on the top of each other, and it just doesn't work no matter what I tried. Maybe I am missing something there.
In order to make a running bond pattern, I ended up using Hatchmaker from Autocad, save it as a pat file, add a %TYP=model at the top of the text. Then import it to Revit for the new modeling pattern. it works fairly well with some extra work but it is free.
(Just FYI, the above process with the extra note %TYPE=MODEL only applies when you are making a modeling pattern, NOT drafting pattern)
Originally posted by Parametric Snowman View PostI have used Hatch 22 before and it works pretty well for "stacked" pattern,then I have attempted to make a running bond pattern a few times, and they all came back stacking on the top of each other, and it just doesn't work no matter what I tried. Maybe I am missing something there.
(Just FYI, the above process with the extra note %TYPE=MODEL only applies when you are making a modeling pattern, NOT drafting pattern)Mark Balsom
HatchKit contains a Brick and Tile wizard for stacked and running bonds - just fill in the numbers and return the finished pattern directly to Revit without wrestling with .PAT files.
There's much more - fill details sketched in Revit can be passed to HatchKit for pattern specification generation and again returned directly to Revit without wrestling with .PAT files.
Very large patterns can be generated and loaded without encountering the Revit Fill manager or its scaling limits.
More details and free demonstration at the HatchKit Demonstration webpage.Last edited by hugha; April 1, 2015, 01:19 AM.
I am trying to make the brickwork hatch (diagonal double lined) more dense for example changing the spacing between each set of double lines.
...November 16, 2015, 10:06 AM -
So out of the box Revit comes with a useful set of hatch patterns which can be used in your projects to create drafting & model fill patterns. The...
Channel: Blog Feeds
September 9, 2011, 10:30 AM -
I'd like to create a custom hatch/ surface pattern.
never done it before and don't know where to start with?
is there a special...July 30, 2012, 08:20 PM -
I am having trouble understanding / finding where the hatch patterns are located. I added a hatch pattern to my REVIT.pat but it did not show up in my...November 3, 2011, 02:20 PM
Hey,
We are crrently in the process of working on a hybid project.
2/3rd of the docs are being done in ADT and the remainder is...February 9, 2012, 07:02 AM
Monumetric Footer In-screen
