hi, i have a beam dimension which is a shared parameter, "h" for height of the beam and "b" for width of the beam.. i want that the "b" will go up first than "h" so that when i do tagging, it will read the "b" first then "h".. what shall i do? tnx.
Dimension (shared parameter)
hi, i want to create a beam tag. and my beam dimensions are shared parameters. how can i add the height and base dimension of the beam on the tag if is...December 6, 2011, 01:30 PM
I wonder, if there is any possibility to add a parameter in the middle of beam family, which control it's curve? I want middle of my beam, to be 3-5...
Channel: Structure - Family Creation
March 29, 2017, 08:37 AM -
What is the easiest and fastest (best way) to put shear studs on the beam. do i have to edit the beam family etc.
February 11, 2016, 12:09 PM -
hi all, i want to create a post tension beam as shown in the attached file. i know i can make it as a separate beams, but i want that that kind of beam...
November 23, 2011, 09:58 AM -
Hi everyone,
I have no idea if this topic has already been highlighted. If so please link to another thread.
It happens a lot...-
April 30, 2020, 09:02 AM -
Monumetric Footer In-screen
