Vertical section Wall+Architectural Columns
    Hello guys,
    I designed a wall, then I drew a close to the wall architectural columns. In plan the two elements come together regularly, while in section the architectural column is separated from the wall. The layers of plaster are wound around the column regularly, but in vertical section also happens inside!
    Moreover, because the layer of plaster also runs above and below the column?
    thanks
    ps sorry for my google english :-)
    Where is your section? Is that the black line through the column?
    What is your View Discipline set to? (you can find it in the view properties)
      HI!
      Yes, the black line, but see other images.
      Discipline on architectural!
      thanks
        Well, I don't know. Could you post the project (or a part of it)?
          Thanks Martijn!
          But... there is no project, but a little discussion on our italian revit forum, regarding regular walls modified with arch. columns. My wall+column is only an example of the question.
          Its a Revit bug?
          ciao!
            Well, I don't know for sure... Could be something weird happening with the extents of your column, wrapping settings, and so on.
            Unfortunately I don't use arch columns a lot, so I wasn't able to recreate the problem here.
            But hey, it might as well be a bug...
              Ok, thank you!
