hi guys, i want to create a shared parameter for my ramp. i want it to be shown in the schedule. is it possible to add a parameter with a formula? because that parameter is a volume computation of the volume of the ramp. i will use the helix 3d formula to compute the ramp volume. but i will create also a parameter for ramp length and ramp area, and i will use this parameter in my ramp volume parameter to compute the volume. is it possible? have anyone done this before?
Shared Parameter Possibility
Originally posted by r7_human8y View Posthi guys, i want to create a shared parameter for my ramp. i want it to be shown in the schedule. is it possible to add a parameter with a formula? because that parameter is a volume computation of the volume of the ramp. i will use the helix 3d formula to compute the ramp volume. but i will create also a parameter for ramp length and ramp area, and i will use this parameter in my ramp volume parameter to compute the volume. is it possible? have anyone done this before?I'm retired, if you don't like it, go around!
Originally posted by Dave Jones View PostI know nothing of ramp construction or helix 3D formulas but normally if you want a computation from a schedule you do it with a Calculated Value in the schedule which creates its own parameter so a shared parameter is not required
Originally posted by r7_human8y View PostHi dave, i tried calculated value in the schedule, but my problem is what kind of formula can you i put? Using the fields in schedule or any direct formula can be applied? Can you show me the process dave of inputting a real formula in the calculated value? Tnx.I'm retired, if you don't like it, go around!
Well, calculated value would be:
Type = Volume
Formula = Length * Area
Quite simple, the only problem is that the ramp is a system family, which you can't add parameters too which refer to the actual geometry. And neither Area nor Length are available as a system parameter in the schedule
A more suitable approach would be the Material Takeoff (which in fact will give you Material volume and surface area) but strangely Ramps aren't in that list. But with Alf's solution in your other thread that problem is solved too since you can schedule the In Place component.Last edited by mdradvies; November 27, 2011, 08:58 PM.Martijn de Riet
Hey there, i was wondering if it is possible, to make a calculated value in a schedule, from an other paramater, which has the same value as another parameter,...March 15, 2019, 02:23 PM
Hello All,
Apologies if the title was unclear. Have a vertical rod stiffener family with nested stiffener family. Depending how long...-
Channel: MEP - Family Creation
December 27, 2018, 06:21 PM -
Guys, Is it possible write formulas into custom created shared parameters? I'm wanting to calculate the weight of precast concrete building elements....
December 4, 2012, 08:08 AM -
I have created a weight parameter for my steel and I can get it to show up in the schedule with a calculated value but I can not get...-
March 25, 2016, 04:25 PM -
Dear all,
This is a tricky one. I am currently making productionsheets for parts and I want to incorporate spares. For example: I need 570...June 17, 2018, 01:18 PM
Monumetric Footer In-screen
