how do I do simple stuff like change wall length?
    I'm a post-novice Solidworks user just starting out in Revit.
    How do I change wall lengths after I've entered them after the temp dimension?
    You can :
    1. select the wall, grab an end (blue dot) and drag manually
    2. select the wall, change the dimension (temporary or placed)
    3. use the align tool to select any perpindicular edge (line, grid, reference plane, element, etc) to the wall, then select the wall's end
      4. Use the trim tool same way as the align tool
        4a. Use the trim to corner tool for a corner OR use the trim / extend tool to trim or extend one wall to the face of another.
        Dan
          5 Edit wall profile, but to simply change length not recommended. Only really if your boundaries of the wall require unequal or non-straight properties.
