Oblique projection in revit
    Is it possible to do an oblique projection in revit? Essentially I want to take a section cut and project the exterior walls to the left.
    Yep. Make your section. Then create a new 3D view and use the Orient to View tool located in the right-click menu of the view cube. the 3d view will orient to the chosen section, and you can then orbit it (or use the view cube) to orient it to an isometric type view.
    Scott D Davis
    Sr. AEC Technical Specialist
    Autodesk, Inc.
    http://bit.ly/aboutsdd
