change instance parameter w/ "Edit" for multiple views/sheets
    these issues may be raised before, forgive me if that's the case:
    1) views, say i want to change VG for multiple views w/o using view template, do i have to open each view to change it?
    2) sheets, say i added new issue/revision and/or new sheet, i want to change "Revision on Sheet" for multiple sheets, do i have to open each sheet to change it?
    thanks in advance.
    - I don't think so, you really need to use the view template if you want to change multiple view. or i suggest set a one view for floor plan and elevation then copy that view to other view.
    thanks in advance.
    -Yes this how it done. but u can also create a sheet list to change the data without opening all the sheet one by one. or also you can add another parameter to your title block and set that as a "type" to automatically change all the sheet in your project.
    Revit Arch 2013 Certified Professional
    Phlippines Revit User Group
    Architecture | Structure | MEP
    International Order Of DeMolay
      uploaded image for clarification
        Check all revisions
        Unfortunately there is no quick solution in basic Revit :banghead:, but there are few tools (add-in) that can get the job done.
        I use this one:
        Xrev Freebies « Products | Xrev.com.au
