How to cut wall into floor without joining
    How to set so wall would count as a column, at it could cut, but not join the floor?
    I don't understand the question very well but if you want to cut the wall's section profile you can do it in the Type Properties by editing the Structure where you can add a reveal profile and adjust it by offset and distance to fit your desired position in the wall's section elevation, dues the wall will have a cut by the profile you load for the reveal and you'll not need to join it to the floor ...
