stairs rising on the other side required ??!
    Hi, i find that riser on the side is not filling althougn next rise did fill.
    why ?
    i attached one for my problem
    and one during sketch mode because solution can come from sketch mode.
    I've had something similar to this happen, but I can't remember how I fixed it.
    Try setting both top and bottom level as the same one, then use an offset. For instance, top would be level 1 with 0 offset. Bottom will be level 1 with - 12" offset (or whatever it is). See if that helps.
    Dan
      It looks like you have green boundary line where riser line should be.
        Dan the suggestion did not work for me, i set base level :1 with offset 0.3meter , base level :1 with offset 0. PijPiwo when i sketch riser line above boundaryline the programme will not let me go (overlapping or something like that cause programme complain .....).
          Take a look at the pics.
            Thanks PijPiwo that exactly what i am looking for. it works but just want to mention that green line is the same path for railing and the path of railing can be edited too. great that i know this info also.
              Ahh, good job PijPiwo. I didn't even notice that. :thumbsup:
              Dan
                thanks you too Dan for trying to help me i appreciate it.
                  No problem. Now that I think of it, I think I started a thread here with the same issue. And that was the solution. I was doing it wrong. :laugh:
                  Dan
