Stop Beam to Column Connection
    I have a beam that is automatically connecting itself to a sloped column in the wrong location. Is there any way to "disconnect." I'd try and explain more specifically, but it's easier to see in the attached stripped down example.
    Not with the families you are using for the column and beams. The beam is being cutback by the top of the column. Why are you slanting the column in the family and not using the Slanted Column option?
    -Alex Cunningham
