why i can not insert wall sweep to wall sometimes ?
    Hi, i am facing problem when i post wall sweep into wall in two direction i got stop symbol sometimes in other project and sometimes is not why it is behaving like that ?
    That looks like the edge of a wall. Wall sweeps only apply to the face of walls (either/both). To get it to turn back you'll need to edit the returns of the sweep.
    Greg McDowell Jr
    about.me/GMcDowellJr
      Only the interior and exterior face of the walls are eligible hosts for sweeps and reveals. This looks like an end face of a really thick wall. This is not possible.
      Jeff Hanson
      Sr. Subject Matter Expert
        Its entirely possible, as GmC said, by editing the sweep return, setting it to 90 degrees, and pulling the tab the full length of the thickness.
          GmC,Aaron , it works as you said thanks. All i did i click on modify returns--then like split cursor appear -- just click on the face of wall sweep end-- then draw the line into direction you want and you will get the connection of wall sweep (cornice).
            just want to know if this is normal the modify return is allowed one time then you have to make add or remove wall -- then you have to make modify return on newadded wall to make it join is this normal ?
              Don't use Modify Return on this one... Select the Sweep, you'll see two blue dots. Stretch those to meet in the corner and the sweep should close automatically.
