Problem with baluster railing degree
    Hi, i have problem that i established the baluster family on front elevation family. now when i loaded into project and give it this setting i end up with this rotation of pattern that supposed to be straight without this opposite turns, how i can fix that ?
    Rotate the baluster in your Family...
      can i rotate the family even if i set parameters to the baluster (meaning to rotate the family along its refrence plane i made or when i rotate i will lose all of this and have to re made all of this refrence planes and parameters)
        You could try this:
        go to plan view, select all refplanes, geometry, and so on.
        Cut to clipboard, Paste from clipboard, rotate (without hitting the escape button). This should keep at least some of the constraints...
        More dirty solution:
        Save as Baluster_nested
        Reopen original and delete all geometry.
        Switch back to Baluster_nested
        Load into original Baluster and rotate,
        Tie parameters together
