Hubs Tracker
    Hubs Tracker
    So you know when you select an element it brings up the modify tool bar for that element so you get "Modify:Floor" if you select a floor and son on. I have a corrupt element in a model of mine that I was able to track down in a local file and when I select it it is called "Hubs Tracker." What in the world is this element?
    Don't have a clue, never seen it before...
      I think he is hacking Revit somehow....
      -Alex Cunningham
        and these are the sentinels send out by Revit to counterattack, track and destroy his hubs?
          Alex reported a buggy element in our template...I searched for it by number...and got the same as the original post
          Any ideas yet?
          -Kirk
          01010010011001010111011001101001011101000010000001 10100101110011001000000110010001100101011000010110 0100
            This element would not allow me to open the project until I did an audit on the central file. Freaky...
            -Alex Cunningham
              I also just found this little doozy of error today.
              Seems I had our whole team get an invalid object at the same time. As I had my local model open and had not been working on it for a while I quickly did a select by ID, and found this Modify-Hub Tracker header but no other information at all.
              Quick audit of the central file and the offending element was deleted and we all seem to be back on track.
