Beam issue!!
    Beam issue!!
    hi, is it possible that the beam end point or starting point like the wall when you right clicking the point there is command that says "disallow join"? because i want my beam not to join with the other beam cause i want it to extend a liitle bit away from the column. is it possible? thanks masters.
    hi, revit masters.. pls tell me if its possible.. what else should i do? tnx a lot.
      I dont have Revit open right now.. but.
      If you change the "z-Direction Justification" of the two beams to differ from eachother... They technically should not auto join anymore.
      -Alex Cunningham
        you may try the unjoin button, Modify tab. Otherwise, extend manually the end of the beam.
        A capture of your screen may help too....
        Julien
        P. DAC
          Originally posted by jbenoit44 View Post
          I have the same problem, but the thing is that I need to make a small (55 mm) gap between different family beams. And they always auto-join... Any suggestion how to trick that?
