is there a fountain element that looks like this in revit ?
    Hi , just wondering if i can have like this element in revit that will also appear in rendering clearly.
    That one would actually be fairly easy, create a sweep along that shap, and array it(polar) and give it a white water texture.
      Here's a quick test
      Fountain, I'll render it and see how it looks. too.
        The spray is the snow material modified to have bump(noise), transparency and self illumination.
          Originally posted by sdbrownaia View Post
          Here is the fountain Rendered.[ATTACH=CONFIG]5149[/ATTACH]
          Wow my friend now would you explain one thing in this rendering which caught my attention? Would you please tell how did you make that beautyful roofing with that separate ridge laying over?
            The roof is a material using a texture I made in PhotoshoP(see attached). The Ridge and Hip covers are a "fascia" added to the edges using a tile shaped arc profile. Then a second material is applied to those.
