Quick Question
    Quick Question
    Hi guys I recently installed Revit 2012 trial version and im just wondering where I can find the family component library? Thanks
    On a default install it should go to C:\ProgramData\Autodesk\RAC 2012\Libraries.
      Its should get installed with the software, when you go to load a family, does nothing show Up?
        Theres a Familys Template folder but no Libraries folder?
          i think he need a link to download from autodesk out of box library come along with programme.
            If it didn't install, re-run the installer from Control Panel, and choose the option to Add Content. You may not have downlaoded it the first time.
            Scott D Davis
            Sr. AEC Technical Specialist
            Autodesk, Inc.
            http://bit.ly/aboutsdd
              Hi Scott,but i think there is RAC library you can download from and this should be in autodesk website.
              and then you can copy the downloaded folder into programme data/Autodesk/RAC...
              so we need a link.
              ahmed_hassan
              Senior Member
                so we need a link.
                The library for 2011 is available here: Autodesk - Autodesk Revit Architecture Services & Support - Templates & Libraries
                For 2012, as Scott suggested :beer:
                    the programme by default will lead you to this path when you willing to put component unless you did not download content which take hours if you do not have high speed. another option is to reinstall revit and make sure you click on check mark of imperial library or metric library.
