error when copying floor level and assigning it to below level ?
    Hi, i tried on this but it seems it do not work i have typical ground floor to first floor with some adjustment. the copying and aligning process work well with second and third floor but with ground floor i got this error message.
    normally we start from first floor as designing start so it is expected that i will copying it to below floor with some adjustment later.
    but why this error message and how i can handle with it ?
    Maybe some of the objects you have on level 1 is constrained to the level below? If that's the case, you´re missing a level below the level below.
      Yeah Munkholm thanks, you are right the stairs want to find level below level of ground so once i created temporarily a level below ground and then delete it later, everything adjust itself automatically including stair.
      ahmed_hassan
      Senior Member
