How to trim or join countertop of kitchen ?
    HI everyone in the forum, i faced a problem that - i have two counter one of them is not 90 degree so when you align one to the wall the other is not align. plus i faced problem of joining two counter when doing furniture in 2d. (the same effect on 3d) can anyone tell me how to fix it ?
    Thanks for the help
    You can not join geometry in the "Casework" category... It's one of those weird limitations in the software... You could however, change the countertops to the "Generic" category instead. Their´s pros and cons to this "fix" so take a minute to think about it before you change it.
    If you don't want Generic countertops, you'll have to apply a parametric angle to the family, and use the Linework tool to make the two countertops appear as one. Or even better, create a new L shaped countertop, still with a parametric angle, and replace the current two countertops with the new one.
      should i use refrence line (not refrence plane) to make it angular parametric ?
        That's how I would do it. Create it once using reference lines, and use it a million times. :thumbsup:
        Dan
          I just made a bent counter top and uploaded it to Revit City .https://www.revitcity.com/downloads...._file_type=rfa Just change the inside angle to bend it. The stretchy depth and lengths are instance parameters. The angle is a type parameter.
