RE: Sheet
This topic is closed.
    RE: Sheet
    Does anyone have a way they have came up with to reference a sheet, not a view on a sheet? I have multiple views pertaining to an area of my building on one sheet, and on the overall I want to show a live reference to that sheet.
    My thought right now is to do a detail and give it a detail number of "." or something similar and place it on the sheet and reference that or/and make a new callout tag that just displays the sheet...
    Any thoughts?
    Duplicate your callout family and type. In the callout family simply remove the label for the detail number and leave the sheet lable. Add the modified family to your duplicated type.
    Someone who is better at describing things might be able to explain this solution a bit better then I can.
    -Alex Cunningham
      That is exactly what I did, cool! Just wanted to see if there were any other ways out there...this method works really well...too bad I can not override the call out lines on this paticular type to be invisible...
        You may want to experiament with visibility parameters on the labels. You might be able to add a yes/no visibility parameter. I havt tried it.
        -Alex Cunningham
