aligned dimension for 3 equal is not working!!
    Hi everyone in this forum, i have 3 lines on site (the site is sloped line) i want to divide them into three offset lines and make like 3 equals = so i used aligned dimension to the three lines to activate equal but once i got to the third line, the programme give me sign that i can not align dimension to the third line. which eventually will prevent me from equal three divisions.
    any suggestion how i can fix that and make aligned dimension to the three division ?
    not even this is working with straight wall in the middle !
    i want the equal division making my dimension equal near to second image
    ahmed_hassan
    Senior Member
    Last edited by ahmed_hassan; November 8, 2011, 11:03 AM. Reason: Adding second image
      Check that the lines are parallel.
        Looks like you're lines aren't all parallel to each other. They would need to be for the dimensions, and thus the equality constraint, to work.
        Greg McDowell Jr
        about.me/GMcDowellJr
          Your dimension is stright but your wall is not parallel to each other. i suggest put first RP or drafting lines to create the 3 equal parts then just move the center of the wall to the Dl or RP.
          Revit Arch 2013 Certified Professional
          Phlippines Revit User Group
          Architecture | Structure | MEP
          International Order Of DeMolay
            When you have placed the dimension, you may want to relocate the anchor point:
            What Revit Wants: What does the Revit equality dimension anchor do?
            Author of What Revit Wants
              If all else fails use a calculator or if you are not feeling lazy do it in your head., then pin em if you dont want them to move.
              mark b
              Mark Balsom
