View templates that set options in the "extents" header
    I can set the "far clipping" but I don't see a way with view templates to be able to set the "far clip setting" (same as parent/Independent) and the ability to set the "far clip offset". Is there a way I can set this for certain views without having to go into each view and change this manually?
    Joshua Kohl
    Eastern Exterior Wall Systems, Inc
    www.eews.com
