How to trim mulions?
    So i have problem, i would like to trim in the bottom and top mullions. How could i do it?
    Or would you make window family instead of using curtain wall?
    Select the vertical mullion and click the two blue #-signs...
    Whether to make it a window depends on a lot of things. Required LOD, how many times are you going to use this? And so on...
