curtain wall won't inbed
    2011
    when i select curtainwall and place it in 12" generic wall it seems t0 go in. i can highlight it ect. i chick inbed in properties. when i look in elevation or 3d it does not show. when i move it outside the wall it appears.
    My bad. First, of course it is embed, not inbed. Inbed is used with naughty humor. Far more important the wall I tried first is slightly curved (doesn't work) it works on straight walls.
    In my case I have a very tight site and must follow the existing building. Anyway to do that ???
    Last edited by Tom Dolle; November 5, 2011, 04:53 PM. Reason: original post is missing important information
    Originally posted by Tom Dolle View Post
    2011
    if you select the curtain wall system (dashed line with two end lines) and hit Edit Type in the Properties pane is Automatically Embed checked?
      yes it is checked
        checked, still doesn't show
          yes it is checked
          no clue then. All of the OOTB curtain walls embed in walls here no problem
            thank you for trying
              Try using Cut Geometry. ( not automatic, I know.)
              Cliff B. Collins
              Registered Architect
              Autodesk Expert Elite
                Try cutting and pasting... what are your Phase settings? Is the GenWall pinned (don't know for sure if that matters)?
                  Please see revised post if you have time......
                    please see revised post if you have time....
