cross section!
    cross section!
    how can I do to put a pattern (like the yellow nell'iimagine) has not put a screen by hand?
    I would like to get a view like the picture 2
    Thanks to all!
    D
    a r c h i t e t t o d a v i d e f a c c h e t t i
    S t u d i o T e c n i c o F a c c h e t t i
    a r c h i t e c t B I M m a n a g e m e n t
    http://www.studiofacchetti.com/
    You can use a Cut Pattern of a solid color for the Wall Material.
    VG>Object Styles>Walls>Cut Pattern overrides
    You can also use "Coarse" detail level in the view, and set the "coarse solid fill" for the walls to what ever color you would like.
    Wall Properties>Coarse Fill setting
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      thanx so much Cliff!
