is it possible to array windows on circular path ?
    Hi everyone in this nice forum, i have like small circular windows on the small height roof , now i want to array this small circular window along the circular path wall?
    how can this happen when i do not have windows symbol on floor plan ?
    any help on this ?
    Use a Radial Array.
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      thanks cliff for reply , i know it but the problem is on which view i can array if this windows does not show from floor plan view ?
        Use a Plan Region, or set the View Depth to "catch" the windows.
        Or--create a new Section, which will come in vertically by default, and then Rotate the Section Marker into a horizontal position and create your own custom "Plan View" thru the windows.
        Cliff B. Collins
