can we make hole in toposurface just like floor ?
    Hi i wonder if we can make hole in toposurface just like floor because i have underground floor that is withing site ?
    You can use the "split surface" command to cut a hole in the topo.
      Or try using a Pad.
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        Thanks,I tried Pad before asking but it is not working it makes a solid separate surface and if you delete it = you come back to the old complete surface.
        split surface works now.
