Auto View
    Auto View
    Hi All,
    Just curious to see if this is possible.
    When a new user creates a 3D view in a project, it will create a new 3d in the project browser with the uers name.
    Is thetre a way to do this for creating other views like floor plans?
    Ideally it woud be great that when a user duplicates a floor plan to use as a reference or working view, it owul be great if Revit could group it under that users name, as per the 3D view. Is this possible?
    Andrew Harp
    BIM Manager GHD
    I believe this is only the case when the user first creates the default 3D view in their local file of a work share enabled file.
