Linked revit model- HELP
    Is there a way I could split the linked Revit Arch. model to edit... without having to press tab and selecting an element all the time??
    If both ceiling heights are same, how do I have one family's color dominate the other?
    I use RAC2012...
    Thanks,
    spndn07
    Type VG, and change the links to show as Halftone, or customize those settings to show all elements of the linked file in red (or whatever color)
    Hope that helps, And welcome to the forum :beer:
      Welcome to the forum. Could you elaborate some more? Add some pictures? I'm clueless on what you are getting at..
        Am starting to think that it may be two separate questions...? Still not clear though.
        And if they are in fact separate questions, they should have been posted as two threads, just for future reference...
