Structural beam system and floor
    So i model my wooden floor like in the picture.
    How can i join structural beam system with the floor? maybe somehow i can put floor voids so it cuts where the slippers are?
    Select one beam, right mouse, select all in view, Modify Tab > Join and select floor?
      Says cant cut joined elements
        If you are using 2012, add a void to the beams, and check the "Cut with Voids when loaded" like explained in this thread: http://www.revitforum.org/architectu...html#post35065
