Batch export to DWF w/ sheet names
    Is this possible? With 'Export DWF' I'm only given two options: Automatic - Long (Specify Prefix) and Automatic - Short. Neither one grabs the sheet name.
    No, it´s not possible to get only the sheet name when exporting... but you can get the sheetname...
    When using the "Automatic Short" you get: SheetNumber.dwfx
    And when using "Automatic Long" you get: SpecifiedPrefix-Sheet-SheetNumber-SheetName.dwfx
    So your best option is to use the later, and manually delete "SpecifiedPrefix-Sheet-SheetNumber-" if you only want to keep the sheet name.
