Zoom into pre-selected set of elements?
    Hi there
    Is there a zoom command in Revit that lets you zoom into pre-selected set of elements?
    Thanking you in advance
    Rob
    hello, in the sense that only the pre-zoom interesting selection?
    a r c h i t e t t o d a v i d e f a c c h e t t i
    S t u d i o T e c n i c o F a c c h e t t i
    a r c h i t e c t B I M m a n a g e m e n t
    http://www.studiofacchetti.com/
      What I'm looking for is that the extents of a zoomed view window area is dictated by the extents of a selection set of element/s.
        I don't think Revit has a "zoom to selection" feature as say does 3dsMax.
        But, you can make a Group, isolate in View, then Zoom extents.
        Cliff B. Collins
        Registered Architect
        Autodesk Expert Elite
          Originally posted by Roberto View Post
          Hi there
          Rob
          If you select some stuff, then use the view cube to "spin" the model by clicking on the sides or corners, it should zoom into the selected items and then use that selection set as a center of rotation.
          Scott D Davis
          Autodesk
          Scott D Davis
          Sr. AEC Technical Specialist
          Autodesk, Inc.
          http://bit.ly/aboutsdd
            Originally posted by Scott D Davis View Post
            If you select some stuff, then use the view cube to "spin" the model by clicking on the sides or corners, it should zoom into the selected items and then use that selection set as a ceter of rotation.
            Thanks but can I get this to work in a none 3D view?
              for 2D (&3d) views...you can also use view region, draw a square over your region and it'll zoom in for you...or you can just hover your mouse and scroll wheel in...there are ways to get where you want to go, but as Cliff mentions above "I don't think Revit has a "zoom to selection" feature as say does 3dsMax."
                Nope... Unless you're in a schedule where you can use the "Show" button...
