Sweep Won't Work
This topic is closed.
    Sweep Won't Work
    Someone please tell me why this sweep won't work. I'm trying to create a light fixture. This is the glass lense. The screen shot shows the profile, and the sweep path (highlighted in yellow).
    If I make just a simple rectangle, it sweeps fine. So my next question would be how would I make this lens shape?
    http://www.lsi-industries.com/lighti...ct.asp?ID=1642
    Dan
    Hi dzatto.
    It would probably be easier to combine an extrusion with a blend - The sweep breaks because it not really a swept form, and is likely to be intersecting it self.
    PS. The top of the blend is NOT a circle
      Originally posted by Munkholm View Post
      Hi dzatto.
      Thanks Munkholm. I figured it was intersecting itself but couldn't figure out how to create it otherwise. Thanks for the tip. :beer:
      Dan
