Independent Scaling for objects on sheets?
    I was wondering if theres a way to change the scale of a drawing placed on a sheet without effecting the scale of the original drawing. I don't need an enlarged plan or want to duplicate anything, I just need the same detail on a new sheet at a larger scale. thanks
    You won't be able to have the same detail placed more than once. Revit won't allow you.
    However, you can right-click on the view in your browser, choose "Duplicate" or "Duplicate with Detailing." When it creates the "Copy of ..." you can then set the scale of the new view to whatever you choose and place that new detail on a sheet.
    Caution: if your detail is a live section or detail, the place where the detail originally was cut will now have TWO detail references. You'll need to go back and make sure you hide one, or adjust it so it doesn't overlap and become unreadable.
    Leanne Zaras, CDT, LEED AP
      Leanne is correct. You cannot place a drafting view or any "View" in your project more than once. Legends and Schedule are place able more than one because they are not a referenced Revit element. If you need your detail to show up more than once (not recommended by any means EVER) you can draw the detail in a legend view. The legend will not be referencable in your plans though.
      Embrace the work flow of Revit and you will have great success with your projects. Duplicating views with detailing looks to be your best bet for what you are trying to achieve.
      -Alex Cunningham
        I guess theres reason behind why I cant
        thanks guys
