Filled Region
    Filled Region
    good Morning Forum! this is my first post have mercy!
    i have a problem with a filled region...i want to scale an import filled region but the parameter Scale Factor is Unvailable.... :banghead:
    how can you fix?
    thanx all
    a r c h i t e t t o d a v i d e f a c c h e t t i
    S t u d i o T e c n i c o F a c c h e t t i
    a r c h i t e c t B I M m a n a g e m e n t
    http://www.studiofacchetti.com/
    Good morning! AFAIK, the only way to change a scale factor for imported patterns is to re-import them with changed scale factor.
      Welcome to the forum! I'd suggest that you take the time to get a .pat file out of Autocad, and use that to create a native Revit Pattern.
      There are a couple of routines for extracting the .pat from Autocad here: http://www.revitforum.org/tutorials-...eneration.html
      And once you've got the .pat file, it'll be much easier to control units, scale, model vs. drafting, etc. etc.
        hi Hirvio....
        thanx so much for the answer! Now, I try!
          thanx Munkholm! i try
