"Breaking" Grid Lines
    Is it possible to do this?
    I have a large building with grids at regular centres. Plan I would like to break the grids so I can annote my floor joints and show them more clearly. Have the gread show at one side and the other side with a clear break in the centre?
    Is this possible?
    Is this possible?
    You have to edit the grid line type and then set the center section to "none" more information is found at the wiki help.
    Creating a Grid Line with a Center Gap - WikiHelp
    Jeff Hanson
    Sr. Subject Matter Expert
      Yep. Just select the grid line and edit the type. In the type settings, you will see a parameter for "Center Segment". Change that to none.
      Now, there is no center segment. There will also be two round blue grips. You can adjust the width of the gap there.
      Jeff was quicker on the keyboard than me. :laugh:
      Dan
        Champion
        Thanks guys
