Render button grey
    Render button grey
    Hi All
    On the default 3D view the render button has greyed out, but on other 3D views it's ok...:crazy:
    It's fine in all my 3D views.
    Dan
      Do you have the same behaviour in all projects, or just this one?
      Assuming it is only this one, I would, in the first instance, close and re-open revit (might be some little gremlin which needs to be booted). If that doesn't work, I would simply delete the view and create a new one.
      Ian Kidston
      http://allextensions.com.au
        Deleting the view and recreating worked - thanks Ian.
        (hard to know if it's you or the program when you're starting out )
          i've been using revit for 4 years and sometimes it's still hard to know!
            Sorry Assem, I should have given some tips like Ian did. Glad you got it to work. :thumbsup:
            Dan
