Does restoring a journal actually work? when I drop it on the Revit icon is dose its thing for a few minuets then throws a fatal error. Or it will just stop all together. :banghead:
This topic is closed.
It can work, so long as nothing has changed since the file was created
Generally I would only try it if I have lost up to an hours work, and I have some sort of crash where I loose all that work.
I would then immeadiatly copy the original file and create a backup.
Run the journal
Hope for the best
I wouldnt try this if you are working on a project with multiple users though, worksharing is fine, but if you physically have a few people saving to central it will most likely not work and be a bit risky to try
The code that should be removed would look somewhat like this:
Code:' 0:< <<Begin build CT>> ' 'Edit mode: IDR_COMMON 'Command: ID_BUTTON_SELECT 'Category: -2000480 'Bar list: ' Dialog_Revit_DynamicLabelDBar ' Dialog_Revit_FamilyBar ' Dialog_Essentials_FilterSelectionNew ' Dialog_RoomAreaPlan_RoomTagPropertiesDlgBar ' Dialog_Revit_EditLoadedFamilyDbar ' ' '*********************************************************** 'CT [Modify | Room Tags]: ' {1} spacer_shr ' {10} Dialog_Revit_EditLoadedFamilyDbar ' 'Cache: ' '*********************************************************** '<<End build CT>> 'E 18-Jan-2011 23:07:20.944; 0:< Jrn.MouseMove 1 , 671 , 422 'E 18-Jan-2011 23:07:20.944; 0:< Jrn.LButtonUp 0 , 671 , 422 ' 0:< Candidates (curIdx = 0): 127754 (-19.734023, +9.715525, +3.937008) 127753 (-15.693587, +8.591965, +4.937008) 'E 18-Jan-2011 23:07:22.348; 0:< Jrn.MouseMove 0 , 452 , 0 'E 18-Jan-2011 23:07:22.348; 0:< Jrn.PushButton "ToolBar , {}{} , Dialog_Revit_EditLoadedFamilyDbar" _ , "Edit Family, Control_Revit_EditLoadedFam" ' 0:< CrsTimer event occurred for 0 times in MFCView [] ' 1:--Post event status Succeeded ' 1:--Post event status Succeeded ' 0:< CrsTimer event occurred for 0 times in MFCView [] 'H 18-Jan-2011 23:07:22.457; 0:< Jrn.Directive "DocSymbol" _ , "[M_Room Tag.rfa]" ' 0:< DBG_INFO: OS_TMP_VSP_ERR: no fixed plane in a view: line 460 of .\Sketch\SketchPlaneInfo.cpp. ' 4:< Connecting session [$ea3ab305] to Worksharing Log [C:\Program Files\Autodesk\Revit Architecture 2011\Journals\journal.0064.txt] ' 4:< Additional IP address/name found for host KM-Pc: fe80::edb1:28aa:80ff:51c3%13 ' 4:< Additional IP address/name found for host KM-Pc: fe80::5efe:192.168.1.10%31 ' 4:< Additional IP address/name found for host KM-Pc: fe80::5efe:192.168.1.11%31 ' 4:< Additional IP address/name found for host KM-Pc: fe80::2054:35dc:a8c7:e868%12 ' 4:< Additional IP address/name found for host KM-Pc: 192.168.1.10 ' 4:< Additional IP address/name found for host KM-Pc: 192.168.1.11 'H 18-Jan-2011 23:07:22.582; 0:< Jrn.Directive "GlobalToProj" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 1.00000000000000 _ , 1.00000000000000, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 1.00000000000000, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 1.00000000000000 _ , 0.00000000000000, 0.00000000000000, 0.00000000000000 'H 18-Jan-2011 23:07:22.582; 0:< Jrn.Directive "ProjToPage" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 1.00000000000000 _ , 1.00000000000000, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 1.00000000000000, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 1.00000000000000 _ , 0.00000000000000, 0.00000000000000, 0.00000000000000 'H 18-Jan-2011 23:07:22.582; 0:< Jrn.Directive "WindowSize" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 900, 587 ' 0:< Before : Create Display Manager ' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< RAM Statistics: 12674 / 16380 567=InUse 567=Peak ' 0:< VM Statistics: 8387123 / 8388607 481=InUse 492=Peak ' 0:< Revit Graphics Information ' 0:< Current Mode : DirectX 9 Hardware ' 0:< Use Hardware: ON ' 0:< Use Overlays : ON ' 0:< START CanUseHardware(forced) 'C 18-Jan-2011 23:07:22.582; 1:< START video card certification ' 1:< VIDEO CARD ENVIRONMENT: CARD="ATI Radeon HD 5700 Series" ManufacturerID="1002" DeviceID="68B8" osID="8192" DRIVER="aticfx64.dll:8.17.10.1047" DEVICE="DX9" FL_Caps="31" (Shader Model) 'C 18-Jan-2011 23:07:22.613; 1:< FINISH video card certification ' 1:< 'Can use hardware: y 'Hardware support flags: 'NotFullySupported n 'FeatureLevelLow n 'DrvOlderThanTested n 'DrvNewerThanTested n 'CardIsNotListed y 'NotCertifiedEnv n '3GBSwitchIsOn n 'SoftwareModeForced n ' 0:< FINISH CanUseHardware(forced) ' 0:< After : Create Display Manager ' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< RAM Statistics: 12674 / 16380 568=InUse 568=Peak ' 0:< VM Statistics: 8387123 / 8388607 482=InUse 492=Peak 'H 18-Jan-2011 23:07:22.613; 0:< Jrn.Directive "ProjToPage" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 5184.41643827052940 _ , 5184.41643827052940, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 5184.41643827052940, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 5184.41643827052940 _ , 0.00000000000000, 0.00000000000000, 0.00000000000000 'H 18-Jan-2011 23:07:22.613; 0:< Jrn.Directive "ProjToPage" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 5184.41643827052940 _ , 5184.41643827052940, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 5184.41643827052940, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 5184.41643827052940 _ , 451.78248240199684, -294.09917040316583, 0.00000000000000 ' 0:< <<Begin build CT>> ' 'Edit mode: 'Command: ID_BUTTON_SELECT 'Category: -2000480 'Bar list: ' Dialog_Revit_DynamicLabelDBar ' Dialog_Revit_FamilyBar ' Dialog_Essentials_FilterSelectionNew ' Dialog_RoomAreaPlan_RoomTagPropertiesDlgBar ' Dialog_Revit_EditLoadedFamilyDbar ' ' '*********************************************************** 'CT [Modify | Room Tags]: ' {1} spacer_shr ' {10} Dialog_Revit_EditLoadedFamilyDbar ' 'Cache: ' '*********************************************************** '<<End build CT>> 'H 18-Jan-2011 23:07:22.676; 0:< Jrn.Directive "WindowSize" _ , "[Project1]", "Floor Plan: Level 1" _ , 1231, 664 'H 18-Jan-2011 23:07:22.676; 0:< Jrn.Directive "WindowSize" _ , "[Project1]", "Floor Plan: Level 1" _ , 1497, 643 'H 18-Jan-2011 23:07:22.676; 0:< Jrn.Directive "WindowSize" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 1216, 925 'H 18-Jan-2011 23:07:22.676; 0:< Jrn.Directive "WindowSize" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 1486, 908 ' 0:< Activate "[M_Room Tag.rfa]" , Sheet: - ' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits. ' 1:--Post event status Succeeded ' 1:--Post event status Succeeded ' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits. ' 0:< DBG_INFO: No matching Revit langId for msLangId. Defaulting to EnglishAmerican.: line 626 of .\Spelling\SpellingCorrector.cpp. ' 0:< Delta VM: Avail -2 -> 8387122 MB, Used +8 -> 488 MB, Peak +1 -> 492 MB; RAM: Avail -7 -> 12672 MB, Used +12 -> 575 MB, Peak +12 -> 575 MB 'H 18-Jan-2011 23:07:23.237; 0:< Jrn.Directive "ProjToPage" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 8560.04758585556740 _ , 8560.04758585556740, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 8560.04758585556740, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 8560.04758585556740 _ , 451.78248240199684, -294.09917040316583, 0.00000000000000 'H 18-Jan-2011 23:07:23.237; 0:< Jrn.Directive "ProjToPage" _ , "[M_Room Tag.rfa]", "Sheet: - " _ , 8560.04758585556740 _ , 8560.04758585556740, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 8560.04758585556740, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 8560.04758585556740 _ , 745.94307649929669, -454.98929691011574, 0.00000000000000 ' 0:< Delta VM: Avail -11 -> 8387112 MB, Used +10 -> 499 MB, Peak +18 -> 510 MB; RAM: Avail -11 -> 12662 MB, Used +5 -> 580 MB, Peak +5 -> 580 MB 'C 18-Jan-2011 23:07:23.269; 0:< idle0_doc ' 0:< <<Begin build CT>> ' 'Edit mode: IDR_FAM_ANN_OBJECTS 'Command: ID_BUTTON_SELECT 'Category: 0 'Bar list: ' Dialog_Revit_DynamicLabelDBar ' Dialog_Essentials_FilterSelectionNew ' ' '*********************************************************** '*********************************************************** '<<End build CT>>
I dont really work with room tags so not sure why it would be hanging, if it is simply crashing and closing out, you would be best to break the journal prior to that point and get it into interactive mode, you could at least recover up until that point
You can simply enter some code in at the point you want to break the journal, it has been suggested in another thread here that activating press drag is a good way of getting into interactive mode
Try adding thisCode:[COLOR="blue"]Jrn.CheckBox "ToolBar , {}{} , Dialog_Essentials_FilterSelectionNew" _ , "Press + Drag, Control_Essentials_AllowPressAndDrag" _ , True[/COLOR]
I am very sorry it is not a room tag that it is getting hung up it is a Ceiling tag. It is happing when I edited it.
But erased it out of the journal but now it goes in to interactive mode. I also tryed theCode:"Jrn.CheckBox "ToolBar , {}{} , Dialog_Essentials_FilterSelectionNew" _ , "Press + Drag, Control_Essentials_AllowPressAndDrag" _ , True "
But i did find the code that is breaking it.
Thanks for the Help
Code:'Edit mode: IDR_COMMON 'Command: ID_BUTTON_SELECT 'Category: -2005002 'Bar list: ' Dialog_Revit_DynamicLabelDBar ' Dialog_Revit_FamilyBar ' Dialog_Essentials_FilterSelectionWs ' Dialog_Essentials_FilterSelectionMm ' Dialog_Essentials_FilterSelectionNew ' Dialog_Essentials_IndependentTagDlgBar ' Dialog_Revit_EditLoadedFamilyDbar ' ' '*********************************************************** 'CT [Modify | Ceiling Tags]: ' {1} spacer_shr ' {292} Dialog_Essentials_IndependentTagDlgBar ' {10} Dialog_Revit_EditLoadedFamilyDbar ' 'Cache: ' '*********************************************************** '<<End build CT>> 'E 18-Jan-2011 08:08:34.375; 0:< Jrn.MouseMove 1 , 328 , 501 'E 18-Jan-2011 08:08:34.375; 0:< Jrn.LButtonUp 0 , 328 , 501 ' 0:< Candidates (curIdx = 0): 3588672 (+10.725777, +142.699222, +22.703125) 'E 18-Jan-2011 08:08:35.140; 0:< Jrn.MouseMove 0 , 338 , 510 'E 18-Jan-2011 08:08:35.140; 0:< Jrn.LButtonDown 1 , 338 , 510 ' 0:< Candidates (curIdx = 0): 3588672--999 (+11.056942, +142.814614, +22.703125) 3588672-0 (+11.066573, +142.928148, +22.703125) 3588672 (+10.992590, +142.878451, +22.703125) 'H 18-Jan-2011 08:08:35.140; 0:< Jrn.Data "Control" _ , "IndependentTag", 1.00000000000000 'E 18-Jan-2011 08:08:35.640; 0:< Jrn.MouseMove 1 , 304 , 510 'E 18-Jan-2011 08:08:35.640; 0:< Jrn.LButtonUp 0 , 304 , 510 'E 18-Jan-2011 08:08:35.671; 0:< Jrn.Key 0 , "Escape" , 0 'E 18-Jan-2011 08:08:36.250; 0:< Jrn.MouseMove 0 , 342 , 509 'E 18-Jan-2011 08:08:36.250; 0:< Jrn.Wheel 0 , 120 , 712 , 708 'H 18-Jan-2011 08:08:36.265; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2233.00031898718860 _ , 2233.00031898718860, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2233.00031898718860, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2233.00031898718860 _ , -5840.70038646946160, -4967.10103270436140, 0.00000000000000 'H 18-Jan-2011 08:08:36.265; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2233.00031898718860 _ , 2233.00031898718860, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2233.00031898718860, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2233.00031898718860 _ , -6768.10544443988420, -5635.81618761001760, 0.00000000000000 'E 18-Jan-2011 08:08:36.328; 0:< Jrn.Wheel 0 , 240 , 712 , 708 'H 18-Jan-2011 08:08:36.328; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2953.14292186055630 _ , 2953.14292186055630, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2953.14292186055630, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2953.14292186055630 _ , -6768.10544443988420, -5635.81618761001760, 0.00000000000000 'H 18-Jan-2011 08:08:36.328; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2953.14292186055630 _ , 2953.14292186055630, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2953.14292186055630, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2953.14292186055630 _ , -9061.11445027174700, -7289.21440811424600, 0.00000000000000 'E 18-Jan-2011 08:08:36.390; 0:< Jrn.Wheel 0 , 120 , 711 , 708 'H 18-Jan-2011 08:08:36.390; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 3396.11436013963430 _ , 3396.11436013963430, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 3396.11436013963430, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 3396.11436013963430 _ , -9061.11445027174700, -7289.21440811424600, 0.00000000000000 'H 18-Jan-2011 08:08:36.390; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 3396.11436013963430 _ , 3396.11436013963430, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 3396.11436013963430, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 3396.11436013963430 _ , -10471.43161781249400, -8306.24656933137160, 0.00000000000000 'E 18-Jan-2011 08:08:36.812; 0:< Jrn.MouseMove 0 , 340 , 514 'E 18-Jan-2011 08:08:36.812; 0:< Jrn.LButtonDown 1 , 340 , 514 ' 0:< Candidates (curIdx = 0): 3588672-0 (+11.066573, +142.928148, +22.703125) 3588672--999 (+11.056942, +142.814614, +22.703125) 3588672 (+11.055606, +142.920781, +22.703125) 'H 18-Jan-2011 08:08:36.812; 0:< Jrn.Data "Control" _ , "IndependentTag", 1.00000000000000 'E 18-Jan-2011 08:08:37.453; 0:< Jrn.MouseMove 1 , 272 , 517 'E 18-Jan-2011 08:08:37.453; 0:< Jrn.LButtonUp 0 , 272 , 517 ' 0:< Candidates (curIdx = -1): 'H 18-Jan-2011 08:08:37.468; 0:< Jrn.Data "Restricted Propagation" _ , 2, 5 'H 18-Jan-2011 08:08:37.546; 1:< Jrn.Data "Transaction Successful" _ , "Move" 'E 18-Jan-2011 08:08:37.906; 0:< Jrn.MouseMove 0 , 315 , 511 'E 18-Jan-2011 08:08:37.906; 0:< Jrn.Wheel 0 , -120 , 693 , 710 'H 18-Jan-2011 08:08:37.906; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2953.14292186055130 _ , 2953.14292186055130, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2953.14292186055130, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2953.14292186055130 _ , -10471.43161781249400, -8306.24656933137160, 0.00000000000000 'H 18-Jan-2011 08:08:37.906; 0:< Jrn.Directive "ProjToPage" _ , "[1013-Wyant Residence_Wade2.rvt]", "Reflected Ceiling Plan: Second Floor Reflected Ceiling Plan" _ , 2953.14292186055130 _ , 2953.14292186055130, 0.00000000000000, 0.00000000000000 _ , 0.00000000000000, 2953.14292186055130, 0.00000000000000 _ , 0.00000000000000, 0.00000000000000, 2953.14292186055130 _ , -9063.46227635869040, -7289.47527767945480, 0.00000000000000 'E 18-Jan-2011 08:08:38.093; 0:< Jrn.MouseMove 0 , 407 , 515 'E 18-Jan-2011 08:08:38.093; 0:< Jrn.Command "AccelKey" , "Cancel the current operation , ID_CANCEL_EDITOR" ' 0:< <<Begin build CT>> ' 'Edit mode: IDR_COMMON 'Command: ID_BUTTON_SELECT 'Category: 0 'Bar list: ' Dialog_Revit_DynamicLabelDBar ' Dialog_Essentials_FilterSelectionWs ' Dialog_Essentials_FilterSelectionMm ' Dialog_Essentials_FilterSelectionNew ' ' '*********************************************************** '*********************************************************** '<<End build CT>> [CODE]
Here is the code that is Failing any ideas :beer:
Hi everyone...i'm in panic..
My revit crashed, and the last saved rvt file was at 4:20PM, and it crashed at 6:30PM...
The journal file is...May 11, 2012, 10:23 PM -
Question .. Have you snipped a portion from a JOURNAL File for scripting or reusing? For example, I have a journal file I run that can zoom-fit on all...
Channel: Third party Add-Ins, API and R&D
May 19, 2011, 12:32 PM -
When you run a journal file in Revit, you get another journal file, a recoding of Revit processing the first journal file, which ends up in the same folder...
Channel: Hardware and Infrastructure
May 31, 2012, 04:07 AM -
I'm not a big fan of desktop shortcuts and usually delete them all, including the one for Revit. How do I run a journal file without this shortcut? I...May 22, 2015, 06:31 AM
Hoping one of you API gurus can help with a rather less sophisticated situation.
I am testing journals, and would like to be able to set a break...-
March 26, 2012, 07:12 PM -
Monumetric Footer In-screen
